Torque specs on fasteners
Double checking all fasteners before I take it out for a spin tonight after doing the engine drop for clutch and oil leak repairs. Are these torque specs correct?
Engine mount: 60 ft-lbs
transmission mount - to body : 30 ft-lbs
Rear coil over lower bolt: 140 ft-lbs
Axle to tranny output flange: 30 ft-lbs (blue locktite)
Shift linkage to tranny shift rod: 17 ft-lbs (blue Loctite?)
Thanks.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 02-21-2011, 10:53 AM
I found the correct axle bolt torque value:
Axle to tranny output flange: 30 ft-lbs (blue locktite) correct value : 60 ft-lbs
Shift linkage to tranny shift rod: 17 ft-lbs (blue Loctite)
Clutch pedal effort impression:
Test drove the car last night. I was amazed at how much lighter the clutch pedal effort was with new clutch and updated fork shaft with bronze bushings instead of the needle bearings. Now, I have to stop my double clutching habit because it just shifts smoothly with a single pedal push.
Next project will be the shift rod universal joint bushings. I noticed the bushings have a little amount of play and might crumble into pieces if not replaced soon.
Engine drop well worth doing !
Old 02-22-2011, 03:47 AM
Banned
You can take all Afasteners product information here
L keys, Pins
Old 03-30-2011, 10:53 PM
