-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Changing Cylinder Temp. Sensor (http://forums.pelicanparts.com/porsche-964-993-technical-forum/599879-changing-cylinder-temp-sensor.html)
cjoenck 03-29-2011 12:58 PM
Is it possible to change the cylinder temperature sensor with the engine in the car or do I have to drop the engine to get to the sensor?
Does anyone have a picture or instructions?
Thank you.
lucittm 03-30-2011 07:42 PM
You may be able to reach the sensor with a partial engine drop. This is documented elsewhere but basically you disconnect everything on the top of the engine - oil lines, gas lines, electrical harness, power steering (if equipped), cooling ducts, and a few vacuum lines. Then with the engine supported by a roller jack, loosen the engine mounts and you should get 6-12 inches of drop. Be sure to block the engine, don't trust the jack and make sure the wheels cannot roll.
Oh, and I'll gladly take your old sensor because I need the oval grommet.
Thanks,
Mark
