Alex Sol's Avatar
Frustrated in Toronto
After rebuilding my motor in 2010, the 964 has been on the rack for the last couple of months. Mainly because the mechanic is slow and busy on other stuff. Plus there was a foot of snow outside most of that time.
I brought the 964 in for what I thought was a hole or gap in the heat exchanger / exhaust gasket and found that number 6 cyl 'spat' out the gasket between the cylinder barrel and head....
Please see pictures.
Wondering what would cause this and if anyone has experience with this.
Thanks in advance...
Old 03-15-2011, 12:33 PM
Alex Sol's Avatar
Old 03-15-2011, 02:14 PM
Alex Sol's Avatar
Alright since no one is jumping in on this one. I'll update it. We pulled out the cylinder barrel (correct me if i'm using the wrong terms), cleaned it up, replaced with fresh sealing ring. I think / hope it may be that the head was not properly torqued the last time.
The head on no. 5 cyl was replaced, intake had to removed on the driver's side. Replaced it and will reset the valves.
Streather's manual suggests intake and exhaust valves to have gap of .004 inch or 0.1 mm. Does anyone set em up differently?
Then, check the timing through the distributor cap. Last time we had trouble with the intake getting 'blown' off.
Replace muffler, cat etc , top with oil and fire it up.
Hope for the best.
Am I missing any steps?
Old 03-15-2011, 09:59 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Alex
Maybe re-tuning the thread title?
or try the engine rebuilt Forum and Post; "What happened here"...
Fustrated in Toronto covers pretty well all sport fans; Maple Leafs, Raptors, Blue Jays, Argonauts
Who Will Live... Will See
Old 03-16-2011, 02:24 AM
Alex Sol's Avatar
good point. and yes the leafs, jays and raptors are underperforming!!
Old 03-18-2011, 09:41 PM
ohh but the Senators are doing well lol lol
Old 04-22-2011, 08:37 AM
JJ 911SC's Avatar
Foreeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Old 04-22-2011, 10:16 AM
Alps Adventurer
Traveller's Avatar
That what happens when you overpay people.
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 04-22-2011, 10:27 AM
Science is NOT optional
rbogh901's Avatar
this gasket problem doesn't happen on the early 964's. hmmm.
PCA member since 1993
Old 04-24-2011, 04:51 AM
Alex Sol's Avatar
no gasket or seal ring in the pre 1991 964s right?
Golf season for the leafs and sens again!
Exciting hockey with Vancouver and Habs still in the running....
Old 04-27-2011, 04:19 PM
Alex Sol's Avatar
by the way, the seal ring was replaced and no troubles so far... unless you read an engine rebuild and electrical issue thread that I am starting!
engine still leaks from spark plug
electrical or fuel pump issue - intermittent... sucks!!!
Old 04-27-2011, 04:20 PM
JJ 911SC's Avatar
It is right now as the Habs tie with a short handed goal
Old 04-27-2011, 05:18 PM
