Oil leak underneath manifold
Hello. I was checking my oil today and noticed something a little strange. The spark plug wires and the connector that holds them together under the intake had oil on them (at least I think it's oil). The wires are dry before and after they go under the intake. I was wondering if anyone had experienced anything like this before and what might be causing it. I noticed some leaking under neath on the drivers side rear but I think that is from the valve cover ((on the to do list). The car reuns normally, no over heating or problem with the oil pressure. I appreciate any input you have. The car is a 95' 993 Carrera2. Also, the leak is not heavy, my oil level on the dipstick is right at the halfway mark.
Thanks, Chris
Chris 95 993 C2 ![]() 84 911 gone to to a new home |
Directly under the intake? Or over on the right side near/below the air box?
Our '95 car had a very small leak in the powersteering hose on the right side... Looked like oil film/oil all over the plug wires and sheet metal on that side. The power steering hose is 1/2" diameter black rubber with a metal restrictor crimped into it. Hangs sort of between AC compressor and side of engine compartment. Hope you can find you leak. Cooper |
Thanks Cooper but it is right under the intake. From the reading I've done and from the thread I have on Rennlist I think it might be the oil pressure sender. Anyone here have any similar experiences?
Thanks, Chris
