Electrical issue speedometer / odometer
Hello,
I have an intermittent electrical issue causing my speedometer and odometer stop functioning a bell will chime and the ABS light turns on the cruise control stops working also the rear spoiler will not go down until everything starts working again. This problem has gotten worse lately and happens almost every time I drive the car. Very rarely will it start working again while driving. But starts out working almost every time I start the car for the first time in a while.:confused: Any advice on where to look for this problem? Thanks for your help, Chuck |
My car had a similar issue and it ended up being an ABS relay. I've seen folks post similar symptoms but have different causes though (speed sensors etc).
Thanks Travis
Where is the ABS relay located?
In the front, passenger side, in the black fuse box to the right of the shock.
There is a small discussion on it...HERE. |
| All times are GMT -8. The time now is 03:30 PM. |
