993 RS Steering Wheel Installation - wiring details within
Took a few pictures while installing a new 993RS steering wheel this weekend. While I was able to find plenty of threads & general info about the wheel/hub, the wiring bits weren't documented so well & lead to a few surprises.. hopefully these help someone else.
The clockspring connectors are interchangeable between 993 / 996 / 986 Boxster. Ordering the wheel from Carnewal gets you the wheel/hub (duh), horn contact plug/pin, & the 2.8ohm resistor.
Part#'s:
Wheel + Hub assembly: 993-347-084-80-8YR
Horn switch contact: 964-652-104-00
Airbag connectors: tbd
Pin for turn signal switch connector: tbd
(anyone know the Porsche p/n's for these? I wasn't able to find anything)
Before we begin, some disclaimers are necessary due to the sensitive subject matter of defeating a supplemental restraint system:
1) By opening this post, you agree to hold the author (me!) completely non-liable for any consequences you incur (or do not incur) as a result of this post.
2) You fully understand the implications and bear the burden of removing an airbag from a vehicle, should you choose to & will not look to blame someone else (especially me) for an undesirable consequence of your actions.
3) You read this on the internet. If something goes wrong, think of how stupid you'll sound when you proclaim to your spouse, significant other, parol officer, parents etc.. 'but I read it on the internet'. Say it out loud now, in the presence of another human to convince yourself how silly this excuse sounds.
4) Your car wants you to die & will try to kill you whenever it gets an opportunity to do so. It is dangerous by nature. Do not assume that because you've named it & have 'love' for it that this isn't true. You're the frog to Porsche's scorpion here..
Disconnect the battery, wait for good measure, then remove steering wheel (already covered elsewhere):
Loosen this 8mm bolt to free the switch assembly:
Wiring bundle happily tied back for ~15yrs:
Taking a closer look, later cars (9*6) will have one orange, one red connector - they are interchangeable:
p/n 964.652.104.00
Presses in from the front:
& pokes through the switch..
adding another pin (#71) to the rear:
Problem is that this pin isn't populated in the mating connector since the horn circuit is carried through the clockspring in airbag equipped cars (photo upside down, look at the upper left cavity in the connector):
[/IMG]
Opening the connector & viewing from the backside:
Old 11-27-2011, 06:27 PM
pt2
Goals -
1) populate Pin71 (Horn circuit) & provide connection to horn circuit in 'OEM-like' manner.
2) Fool airbag diagnostics to prevent fault code / warning light.
Rules -
1) do no harm - no cutting of underdash harness or hokey wiring that can fail, short, or cause future headaches.
Solutions -
1) obtain mating connectors from Porsche salvage yard (Oklahoma Foreign was accommodating & helpful)
2) obtain 2.8ohm resistor to mimic airbag
3) make jumper harnesses as below:
Parts:
Airbag control module diagnostic foolery:
Horn wiring jumper harness (brown-only wire is the original ground, don't have the correct tools to de-pin these yet so it will wait as is):
Soldered & heat shrinked (use a glob of liquid electrical tape underneath heatshrink to keep moisture out):
Pin71 again - if you'd rather be 'creative', splice Pin71 to the brown wire w/ white stripe via any means possible. You've been warned though..
Populated into connector:
From the mating side:
plugged in (brown-only wire is the original ground, don't have the correct tools to de-pin these yet so it will wait as is):
Loosely secured with zip-tie:
Installation is the reverse of removal:
Old 11-27-2011, 06:29 PM
pt3
Column shrouds / trim reattached (replace with 964 parts for improved fit / finish - not pictured)
Horn contact rides along slip ring to complete horn circuit (wheel is upside down in photo, black tab must be on left side to install)
Adjust switch assembly to ensure contact to slip ring on hub (gently pull toward you until it touches the back of the wheel / hub), view from top:
Tighten 8mm bolt:
Attach connectors on backside of horn pad:
Test the horn!
(vid goes here)
Behold, a proper 3-spoke wheel:
Order 964 trim pieces to avoid gap w/ 993 steering column trim:
Old 11-27-2011, 06:30 PM
great write up .
i love that wheel .
i'll add that you can buy a porsche part to disable the bag on a uk 964 , and i'm pretty sure it disables both bags on usa 964s and all 993s.
its a 928 part and plugs in within the center console carpet .
also the 964 carrera rs cowl plastics are a slightly better shape if you're fitting any wheel .
the standard 964 parts dont look out of place however .
you may also have the shave the opening a couple of mm bigger as it may catch on the wheel-hub .
Old 11-29-2011, 12:35 PM
