Front brake pad sensor needed
I managed to break one of the front brake pad wear sensors during my caliper rebuild. If you have a new one that you're not using, please let me know. I need this sooner than later. :)
The part number is: 964.612.363.01 Here is the item: http://img.photobucket.com/albums/v4...rts/sensor.jpg Andreas |
The sensor is already damaged, so you can just cut the wire between the sensor and plug and join the wires together and insulate with shrink sleeve to turn off the brake sensor light in the dash instrument.
But I'd still like to replace the sensor. Andreas |
| All times are GMT -8. The time now is 07:43 PM. |
