rs america no start
have a 93 rs america here with a no start issue. it cranks but with no spark and no injector pulse. there is no constant power getting to the ecu.
i have tested the ecu, dme relay, fuse, fuel pump fuse and replaced the crank sensor.
what else can cause this or cause no power at the ecu?
thanks, nick
Old 06-24-2011, 06:09 AM
I'm actually in the same boat with my '93 C2. Does your car have the factory alarm? mine does and it's my belief this is causing the problem but I haven't had a chance to fix this yet.
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 06-24-2011, 07:41 AM
Do you have permanent positive to pin 18 in the DME (ecu)?
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 06-24-2011, 08:18 AM
no i do not.
Old 06-24-2011, 10:11 AM
