KTS301 (Hammer)1889 C4
Dear All
I have a Bosch KTS301 with the special Porsche software, I can not read the DME info, but I can read the AC/Heater module. I can not read the ABS or Alarm module? How dose the Hammer read each module?
I can load the basic Porsche module and read the DME info? (KTS300)
I made the the cable using 12V and ground-L Line and K Line are hook up?
I hoping to find some one with experience with the Hammer(KTS301)
Andrew
Old 07-08-2011, 06:29 PM
I have the hammer w/version 8. If you are not reading all the control modules I would suspect either the k or l line is not working. Use the factory manual. L line transmitts. K line receives. Usually I have seen a problem with the alarm module shorting k or l. This would prevent comm with all the other modules. Pull the alarm module and flex the wire bundle to see if the comm returns. I've had lots of problems with wire flex around the yellow connector.
Old 07-09-2011, 06:07 AM
