1991 964 Cab rear seat center pivot bracket wanted
I'm deleting my Rear Seat Delete RSD and trying to put together all the pieces needed to reinstall back seats in my car. It is a tan interior (champagne, but black seats would do nicely!).
I'm looking for someone who may have, or know someone who has, the center pivot bracket. Typically, it needs the spot welds drilled to remove from a donor car. Please let me know if you may have this. See illustration 801-15 for the 964 model, part #3 911 501 041 61 (lower pull type release) or 964 501 041 00 (upper button release). See attachment.
Peter
1991 964 C2 Cab.
Old 11-06-2012, 11:41 AM
Peter, thank you so much for finding these in the PET.
I'm thinking of adding the pivot and seatbacks to my car, but I can't figure out why there are two listed under the PP site under 964-501-041-00 and what the difference is between 911-501-041-61 and 964-501-041-0.
I presume that there are two vendors that supply 964-501-041-0, and that 911-501-041-61 is for the cars pre-964????
Finally, why wouldn't you just order the part from Pelican . . . it's like $20.
Old 11-09-2012, 07:56 AM
Different part for either seats with upper button release or lower pin release. PP and Porsche have no stock. Likely needs cut from a donor.
Old 11-09-2012, 08:57 AM
That clears it up! Well, if you find two in your searching please give me a look.
Old 11-09-2012, 10:15 AM
anyone...?
Am still looking for the rear seat center pivot. May need to be cut or drilled from a donor car. I ordered a $40 part from the dealer, but it is not the same as the one I need. I'm looking for the 1/2 moon shaped center piece that the two seat pins ride on and engage in their locking holes to hold the seat backs in the upright position.
Here is the one I need:
Here is the one that was delivered:
Would be very helpful to me as I try to reinstall seats in my 1991 cab.
Thanks ever so muvh,
Peter
1991 964 C2 Cab.
Old 01-04-2013, 07:38 AM
help please...
Hi guys! I just bought a 964 and need the part that I encircled. Any help would be much appreciated. Thank you pi5tolpete for the picture. Sorry it was the only reference I had.
Old 08-08-2013, 09:05 AM
