Throttle response
Looking for help re this question. My 964 seems to have a lazy throttle response. the car is driving perfect and throttle seems Ok but when I blip throttle on pedal or engine it seems very lazy and even seems to miss/not respond if blipped quickly.
Anyone suffer from this or any ideas of remedy?
My last 964 was instant and i am a little worried that its not working properly at low revs.
Apologies for poor explanation but hope this makes sense?
boydyrs
Old 07-26-2011, 04:57 AM
Check the distributor belt is not broken
Andrew
Old 07-26-2011, 05:56 AM
Thanks i will do but it has a vent kit on it so would hope not.
is there a quick way to check the dizzy belt?
Anything else that should be checked?
Old 07-26-2011, 06:19 AM
OK so took the lead out of primary, started engine and ran Ok so think we can presume belt is OK.
Still stumped?
Old 07-26-2011, 06:45 AM
Tiptronic or manual?
Does this happen when cold, hot or at all temperatures?
Other possible issues could be - in no particular order:
- Fuel pressure regulator
- Fuel injectors
- MAF door not moving freely
- Vacuum leaks
- Cylinder head temp sensor
Hope this helps.
'91 C2 Targa
Old 07-26-2011, 09:45 AM
