964 IGN Timing
I have a 964 with a Varioram running a VEMS ECU. I am trying to dial in the timing. Looking for a base IGN MAP from a VARIORAM 993. VEMS runs MAP and RPM as reference points on the IGN Table. I have attached 3 tables, 1. Stock 964, 2. IGN Timing I used on last Dyno Run. 3. A Motec IGN map from a friend. The first 2 tables have a much greater advance in the mid RPM and Low MAP than the MOTEC does.
Old 08-17-2017, 01:56 PM
Well you can tell I am new at loading pictures - Here is MOTEC again
Old 08-17-2017, 01:59 PM
