'92 964 clutch shaft
Does anyone have info on the needle bearings for the clutch fork shaft? I have the engine and transmission out and the needle bearings are in pieces. I need to replace these obviously. I only find these bearings listed in a different application on the 993 list. Any info would be greatly appreciated. Also there are plastic seal/spacers on the shaft, are these available?
thanks in advance,
Kevin
'79 Coupe
Old 08-08-2011, 05:16 AM
I don't see the needle bearings in the Pelican catalog.
When I did my clutch last year, I updated the fork cross shaft and needle bearings with an upgrade kit using bronze bushings instead of needle bearings.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 08-08-2011, 08:40 AM
Bubbling well's Avatar
Same here. Did it in February. It's little more expensive but less parts and (nearly) maintenance free. I can't seem to find this kit from Pelican, neither. So try here if you're interested. Zim's Autotechnik G50 Release Bearing Fork Shaft Update
bW
Old 08-08-2011, 09:07 AM
