-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   964 Oil leaks & fixes thread. (http://forums.pelicanparts.com/porsche-964-993-technical-forum/644446-964-oil-leaks-fixes-thread.html)
perelet 12-11-2011 12:06 PM
I do not post too much, mostly read the boards. 964's do leak pretty badly by nature, but not all leaks are caused by "case cracks", "cylinder heads" recalls, case bolts and other terrifying causes widely spread on the net.
A lot of leaks are easy/fun to fix DIY. They also can turn out to be nightmare and $$$ poured in to pockets of "wrenches"/indies with questionable reputation.
Anyway, here are few fixes that you can do without removing engine from the car and minimal amount of special tools. Initially I'll cover timing chain covers, power steering pump, oil return line - which are very common. My car is 1990 5sp, 71K miles.
1. Timing chain cover leaks.
http://dl.dropbox.com/u/52900356/lea...inGaskets.jpeg
All gaskets causing leaks are marked red. Can easily see from under the car:
http://dl.dropbox.com/u/52900356/leaks/IMG_7312.jpg
Driver side cover is very easy to get to. You need to remove mufflers, cat and rear engine tin. If you break some exhaust fasteners (and you will) - it is normal. Order all new.
http://dl.dropbox.com/u/52900356/leaks/IMG_7315.jpg
also "Zero out" engine and remove distributor - follow widely described procedure.
http://dl.dropbox.com/u/52900356/leaks/IMG_7367.jpg
If you have correct spark plug wires they are labeled with distributor and spark plug numbers.
http://dl.dropbox.com/u/52900356/leaks/IMG_7358.jpg
So here it is:
http://dl.dropbox.com/u/52900356/leaks/IMG_7380.jpg
and new parts
http://dl.dropbox.com/u/52900356/leaks/IMG_7390.jpg
To get pass side cover off, you'll need to support engine by jack stands, remove engine mounts, and remove bumper.
http://dl.dropbox.com/u/52900356/leaks/IMG_7340.jpg
Disconnect belts and AC compressor:
http://dl.dropbox.com/u/52900356/leaks/IMG_7407.jpg
and AC compressor (leave AC lines connected):
http://dl.dropbox.com/u/52900356/leaks/IMG_7348.jpg
Next is to remove engine pulley/balancer bolt :
.... have to split posts - reached max number of images per post. To be continued ...
Oleg
perelet 12-11-2011 12:27 PM
http://dl.dropbox.com/u/52900356/leaks/IMG_7401.jpg
many methods exists - impact works fine for me.
to remove pulley you'll need special tool:
http://dl.dropbox.com/u/52900356/leaks/IMG_7406.jpg
Now you'll see rather ugly AC bracket that blocks access to pass side cover:
and also condition of your crank seal.
http://dl.dropbox.com/u/52900356/leaks/IMG_7413.jpg
Unbolt bracket and you have access to another timing chain cover:
http://dl.dropbox.com/u/52900356/leaks/IMG_7414.jpg
And chain tensioner gaskets (I used gasket sealant on those ones):
http://dl.dropbox.com/u/52900356/leaks/IMG_7416.jpg
remove cover, clean it up, replace gasket and rubber rings.
While there replace gaskets seals for oil bridge
http://dl.dropbox.com/u/52900356/leaks/IMG_7491.jpg
NOTE. There's typo in PET - you'll need 4 999-7-1-909-40/17 seals, not 2 as it says,
also 999-707-288-40/213 is black and one that you most probably will see in the car is orange.
Also, replace chain tensioner gaskets at same time. I used gasket sealant on those ones cause they tend to warp:
http://dl.dropbox.com/u/52900356/leaks/IMG_7400.jpg
perelet 12-11-2011 12:42 PM
While there.
Oil return pipe bolt tends to get loose and leaks oil on heat exchanger producing that 964 specific smell that my wife hates:
http://dl.dropbox.com/u/52900356/lea...turnPipe1.jpeg
here's real life pic:
http://dl.dropbox.com/u/52900356/leaks/IMG_7311.jpg
To get there you'll need to drop heat exchangers .... sooner you get to remove them, easier your future life will be. Nuts tend to rust & studs can break. Sooner you replace them - better.
http://dl.dropbox.com/u/52900356/leaks/IMG_7327.jpg
In my case some nuts get off, some nuts got stuck and I ended up with studs. Also I had to "fabricate" 13mm wrench to get exhaust nuts. I used HF 12/13mm combo offset wrench as source:
http://dl.dropbox.com/u/52900356/leaks/IMG_7330.jpg
Exchangers out:
http://dl.dropbox.com/u/52900356/leaks/IMG_7333.jpg
Now you have access to 36mm nut on return pipe. In most cases end nut on the pipe get's loose. But also, there coupling and crush washer. Also, in my case Oil relief bolt was loose also:
http://dl.dropbox.com/u/52900356/leaks/IMG_7423.jpg
Here are parts for washer etc. I'll cover upper part later:
http://dl.dropbox.com/u/52900356/leaks/PETCaseLeft.jpeg
perelet 12-11-2011 12:50 PM
2. Steering pump seals replacement.
http://dl.dropbox.com/u/52900356/lea...eringPump.jpeg
typically demonstrates itself as mess on pass side heat exchanger, cylinders:
http://dl.dropbox.com/u/52900356/leaks/IMG_7313.jpg
This procedure can be done with engine in the car also.
... to be continued ..
perelet 12-11-2011 04:18 PM
At this moment I had heat exchangers off. To get more space I removed rear strut:
http://dl.dropbox.com/u/52900356/leaks/IMG_7428.jpg
then I disconnected oil line and removed muffler bracket.
http://dl.dropbox.com/u/52900356/leaks/IMG_7429.jpg
off goes lower belt gear:
http://dl.dropbox.com/u/52900356/leaks/IMG_7432.jpg
Here's view:
http://dl.dropbox.com/u/52900356/leaks/IMG_7436.jpg
Now few more bolts here and there and steering pump can be removed from housing:
http://dl.dropbox.com/u/52900356/leaks/IMG_7437.jpg
http://dl.dropbox.com/u/52900356/leaks/IMG_7442.jpg
Bad parts:
http://dl.dropbox.com/u/52900356/leaks/IMG_7439.jpg
http://dl.dropbox.com/u/52900356/leaks/IMG_7440.jpg
New seals:
http://dl.dropbox.com/u/52900356/leaks/IMG_7475.jpg
http://dl.dropbox.com/u/52900356/leaks/IMG_7478.jpg
oops run out of single post limits again - see next
Oleg.
perelet 12-11-2011 04:20 PM
and installed cover:
http://dl.dropbox.com/u/52900356/leaks/IMG_7500.jpg
To torque bold apply parking brake - it's enough to get required 88lb/ft
http://dl.dropbox.com/u/52900356/leaks/IMG_7502.jpg
Belt just fits the gear there's no tensioning mechanism.
perelet 12-11-2011 04:57 PM
3. Valve covers.
http://dl.dropbox.com/u/52900356/lea...lveCovers.jpeg
With things apart to that level addressing valve covers, doing valve adjustment and changing spark plugs is pure pleasure. 964 105 902 00 is part number for valve cover kit that has everything needed, but I also suggest ordering few extra studs - one above cat get cooked.
Valve adjustment is pretty much like on every other single cam car (I used to own BMW 2002's and older 5 series with big sixes)
Take tool:
http://dl.dropbox.com/u/52900356/leaks/IMG_7449.jpg
put engine in right position (addressed all over books and web), check the gap:
http://dl.dropbox.com/u/52900356/leaks/IMG_7454.jpg
adjust if needed. Somehow people make big buzz out of valve adjustment - it's not.
Nastiest thing about this part is to deal factory paint bubbling on magnesium valve covers - yuck:
http://dl.dropbox.com/u/52900356/leaks/IMG_7448.jpg
Using spray paint stripper on valve covers is NFG:
http://dl.dropbox.com/u/52900356/leaks/IMG_7459.jpg
Gel pain stripper is one of nastiest chemicals you can buy.
http://dl.dropbox.com/u/52900356/leaks/IMG_7461.jpg
but be warned this stuff is nasty, here's enlargement from previous pic:
http://dl.dropbox.com/u/52900356/lea..._7461-copy.jpg
Even after letting it soak in deadly gel, some paint still was left inside. Well, glass blast it:
http://dl.dropbox.com/u/52900356/leaks/IMG_7466.jpg
I'd rather hang them on the wall:
http://dl.dropbox.com/u/52900356/leaks/IMG_7470.jpg
You will need to prime and paint exposed to open air surfaces - magnesium rusts (get's darker) very fast.
Misc notes:
NOTE 1:
With all that nastiness outside spark plugs after 70K miles look absolutely clean. Old vs brand new:
http://dl.dropbox.com/u/52900356/leaks/IMG_7471.jpg
NOTE 2:
Rear pieces weighted:
Bumper with insides 40lb
Cat 16lb
Premuffler 24lb
Muffler 23lb
Manifold1 18
Manifold2 13
exhaust alone is almost 100lb. No surprise C4 Lightweight was so light and quick - it had headers only, but slso it was loud....
Oleg Perelet
perelet 12-11-2011 05:10 PM
4. Upper seals. I did them few years ago, can't find pics. If I find I'll post. Or somebody else who did it please add pics. Mainly - remove intake manifolds and you'll get access to top part of engine. I marked ones that I had to replace.
http://dl.dropbox.com/u/52900356/lea...CaseRight.jpeg
Disregard #23 on pic below - it was addressed before in oil return pipe post.
EDIT. Found some older pics.
Remove pass side part of intake out from car - it is matter of loosening clamps. You can keep driver side intake manifold in car, but disconnect it from engine. Same about mid section.
http://dl.dropbox.com/u/52900356/leaks/PETIntake.jpeg
Now you have some lose parts that will let you to reach back of the engine. Looks much busier on the pic than it is in real life:
http://dl.dropbox.com/u/52900356/leaks/IMG_4063.jpg
One can take time to disconnect all hoses hoses and electrical connectors and take both manifolds out, I do not see any reason for it, except for better photo opportunity
I did not took too many pics at that time. Here closeup of area where arrow points on previous photo - is view with breather casting (part #30 in 2nd drawing) removed:
http://dl.dropbox.com/u/52900356/leaks/IMG_4067.jpg
All other components aka oil pressure sender etc are in same area.
Oleg Perelet.
perelet 12-11-2011 05:12 PM
For DIY enthusiasts I suggest doing what I described before going in to "cracked case" or other nightmare scenarios. You'll learn your car, won't break bank - whole thing is at most $500 for seals, bolts, gaskets. And you'll have fun.
Please feel free to add other leaks that I missed + DIY that you did your own SmileWavy
Oleg Perelet.
porterdog 12-11-2011 08:17 PM
Wow, nice job. Thanks for including the part prints.
adeak1 12-12-2011 06:02 AM
Dear Oleg
Can you explain the repair on the pass side heat exchanger, cylinders?
Pictures please
Andrew
rbogh901 12-12-2011 11:35 AM
Oleg, well done. This is a keeper.
perelet 12-12-2011 05:34 PM
Originally Posted by adeak1 (Post 6426834)
Dear Oleg
Pictures please
Andrew
Hello Andrew. In my case front pass side of engine was wet because of 2 reasons -
1. Top leaks dripping down, oil breather tube is routed to the pass side and and most of leaky sensor seals/washers - see "4. Upper seals." post above, I edited it and added few pics to it. I did it awhile ago and did not took many pics.
2. Steering pump and/or steering gear seal and o-ring. Maybe just leaky hose from reservoir to pump , but you must be lucky to have that. See "2. Steering pump seals replacement." post above.
There maybe other reasons.
If yours is wet you may start with top part - it can take 1-2 weekends, risk of breaking things/messing up is relatively low. Note if it makes it better, if not do lower part:) - that may take 2-3 weekends
Oleg.
occb2 12-12-2011 07:09 PM
Messed up thing is that I just paid over $2000 to do all the leaks you just spoke of. I wish I would have seen this thread first.
Robert
chaw704352 12-12-2011 07:41 PM
Great write-up. I think I caught all these and more on my oil seal refresh. I am also adding in camshaft seals (which means re-timing the cam), the rear main seal and the front main seal (which are fairly easy after you figure out how to go about it).
redturbo911 12-29-2011 05:26 AM
Pretty good info and the picture to guide us are great to actually see it as its talked about. Thanks.
Vandit 12-29-2011 07:03 AM
This is great! I'm going to be in there soon removing the engine carrier to reinforce and replacing the engine cooling fan, so I might tag on these tasks too.
What primer/paint do you use on the valve covers?
Also, I'm assuming the car should be drained of motor oil prior to starting?
Flat6pac 12-29-2011 02:26 PM
I think the biggest problem is the warpages of the chain boxes and valve covers..and they went back to magnesium as though they didnt learn anything in the 70s.
Bruce
Vandit 12-29-2011 02:32 PM
Is there a remedy for warped pieces aside from updating to the CNC aluminum pieces available through the aftermarket (for valve covers at least)?
I've read people mention using a flat piece of glass and emory cloth to alleviate some warpage, but is this method advisable and/or effective?
perelet 12-29-2011 05:57 PM
I used ppg epoxy primer and generic high temp engine paint. Goal is to protect magnesium from weathering.
Yes.
Oleg.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
