RichPugh's Avatar
Anyone have any OZ Mito 1 Modular / Techart Championship Formula M512 Center Caps?
I bought some used Techart Championship Formulas (based on the OZ Mito 1 modulars) that came with 3 original Techart caps and 1 oddball. The oddball cap is totally different so even if I found a new Techart emblem badge, it wouldn't work on it (its convex and sits 1/8" deeper in the wheel).
Anyone have a set of OZ Mito 1 Modular caps or Techart caps on the M512 base? The cap is a hair over 2-7/8"... almost 2-15/16" so I assume its a 73mm or 74mm cap. The Techart badge emblem attached to it is perhaps 70-72mm.
CCD has one OZ cap for $99!! silly...
Or, if anyone has any alternatives (other than finding 3 more N12 caps and getting OZ sticker type emblems for those?), let me know.
Here's some pics for reference:
Old 10-13-2013, 09:32 AM
Couple of questions for you. Does that 4th odd ball cap snap into the wheel center? -- What I did on the last set of Champion Techart (made by OZ Racing) wheel I restored and sold -- I had four of the Techart center caps - with no broken tabs. I wanted a better center cap, so I took a metal Porsche crest center cap and removed the metal portion off the back that allows it to snap in and then I made it fit on top of the plastic Techart cap. I removed the crest by pushing it out from the backside so I could paint the metal center cap to match the wheel center and then I took 3 very small screws and attached the metal cap to the plastic cap under where the indent for crest and attached with a small nut so the unit became one. I then glued the Porsche crest back into the metal cap.
jdorociak@gmail.com jim
Old 10-25-2013, 12:02 AM
