993 Jacking points and jack stand placement
If the jacking points on the 993 are the only place I can put my jack stands how can I jack up the 993 and place my jack stand in the same location? From what I've read I have to place the jack under the engine. My lower engine cover is on and I don't want to have to remove it. Is there another way of accomplishing this or do I have to remove the engine cover? http://forums.pelicanparts.com/uploa...1325107297.jpg
I place the rear stand under the rear suspension mounting point.
But you should remove the rear sound tray anyway. |
I have a flat top jackstand and the rears go on "#6" below:
http://forums.pelicanparts.com/uploa...1205957037.jpg |
Remove the engine tray! It serves no purpose other than hiding a leak. First thing I did on all 3 993s I've owned.
How is the tray removed? Is it best to jack up one side to get access to the tray?
Yes, it' easy to get to the tray....You can almost remove it without jacking the car up....there's 4 screws that hold it in place. It's basically worthless even after you remove it. You would have a hard time giving it away for free!
I am also interested in an answer. The jack supplied with my 993 is downright dangerous. While attempting to jack up my car the jack would snap/slip out sideways.
To date what I have been able to figure out is this. Dispite the owners manual stating that you may only raise the car at the jacking points (front of rear wheels and behind front wheels) proceed as follows. For the rear position a proper hydrolic floor jack with a block of wood in position directly under the engine at the oil drain plug location and raise the vehicle. Once high enough place jack stands under the jacking points. Up front it is still unclear to me what can be done. What I did was use 2 2x6's about 5' long screwed together long enough to span the front jacking points. Then I added a block of wood the size of the jacking point ontop of the 2x6 at the jacking point on each side so that the car jacking points supported the weight. I then positioned my hydrolic floor jack in the centre of the 2x6 beam and raised the car high enough to remove the wheels. I then placed wood blocks under the 2x6 beam to maintain the height I needed. I have a drive on car lift in my garage so when my 993 is on the lift ramps it adds about 4"-6" of clearance so I can get the jack and wood underneath. Without the lift you may get the 2x6 under the car in position but I doubt if you will get a jack under that. |
Just wondering because I've done quite a bit of work and have never used a jack stand, yet. |
I've had these for a few years.
Safe T Jack Heavy-Duty Hydraulic Lifting System — 2-Ton Capacity, Model# 38052 | Jacks | Northern Tool + Equipment Allows you to jack up the car, leaving the jackstand, remove the jack, and go over to the other side and repeat. Also serves as a regular jack. You may need to get the car on 11/2" block for clearance. |
This is the procedure I use every time I change the oil:
1 Jack drivers side up (on jack point in front of rear tire). Remove engine tray. This step is dangerous because only the jack is supporting vehicle. 2 After the engine tray is removed, go back to drivers side of vehicle and place jack stand on front mounting point. 3 Remove jack. At this point in time, your Porsche is teetering in the air sideways with only 1 jack stand under the drivers front. 4 Go around to the passengers side and place the jack under the jacking point in front of the rear wheel and jack up. Place a jack stand under the front mounting point and remove the jack. At this point in time, you will have both jack stands under the front mounting points and the front of the car will be up in the air. 5 Go to the back of the vehicle and slip the jack under the engine. There will be a seam where the engine case is bolted together. Place the jack on the seam and jack up. Then place both jack stands in front of the rear wheels under the jack stand mounts. Remove the jack and your Porsche will be suspended on all 4 jack stands. It sounds more complicated than it really is. You will need a very low profile jack to make this work. This is because the vehicle has both front jack stands installed and the vehicle is tilted in such a way that the rear of the vehicle is very low to the floor. |
Jackpoint Jackstands |
I use the same method as rbi450sl. (But in the future I plan to remember to slip a hockey puck or at least a folded newspaper between the jack and the engine when lifting it up, although my memory is far from perfect.) I use the Esco flat-top jack stands that I purchased from our host, and a Harbor Freight low-profile jack (which also reaches almost 24" after slipping under something about 2-1/2" off the ground). Every one of those items was worth every penny, and really not all that expensive compared to the headache you get worrying about how to jack your car up.
You mention that jacking it up from the engine is "recommended". By whom? Porsche specifically states not to use the engine for jacking. You increase the risk of rupturing your motor mounts doing so. Cross member is safer.
http://www.hts-direct.co.uk/ |
How To Jack Up A 993 - Rennlist Discussion Forums
I use this method. its quick, and i found it to be stable. It seems common place for 993 owners to jack by means of wood (or hockey puck) under the engine block. If the cars couldnt handle it, im sure they wouldnt be doing it. There'd be threads ad nauseum about how bad it is, and things being damaged. Also this same method is described in two very acclaimed books, "The essential guide to 993" and "911 performance handbook" . |
Curious minds wanted to know.
Right out of my 1995 Porsche 911 Carrera 911 Turbo Owner's Manual...
That puts that to rest and if you don't agree, take it up with the designers...Porsche AG. BTW, its also in their 2009 Owner's Manual. |
ok.
do you feel better? i will, as will many others and prob 90% of forum users, continue to use the engine... 747, i would def remove the lower engine cover regardless. |
| All times are GMT -8. The time now is 05:52 PM. |
