89 c4 front hub removal
Please let me know if both, l&r nuts are r.hand thread and can anything be damaged using common sense when loosening the nuts, because they are
probably over 280 ft. lbs.or ? newtonmeter. I plan on using approx. 1 meter
extension to loosen.=======Thanks+++++++++++++++
Es kommt nicht darauf an wie schnell man in die kurve geht, sondern
wie gut die Driftkuenste gedeihen!!!
Old 03-09-2012, 01:02 PM
This is how I got the rear ones off. I had my lady friend sit in the car and depress the brake pedal because the hand brake wouldn't hold the rotor. Probably our only option on the front.
The thread direction should be normal, not reversed.
I'm not sure if it's possible to get the socket onto the nut w/ the wheels on the car and the wheel center cap removed.
I'm guessing you could use an impact tool.
Old 03-09-2012, 01:33 PM
