Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
B. Elliott's Avatar
Won't idle / super rich
I just got everything back together and tried to start her earlier. After charging the battery and trying to start it she immediately backfired and separated the intake manifold... Found a couple of plug wires in the wrong spots on the lower drivers side bank. Fixed those and then got the manifold back together.
Second try and primary issue; She will turn over and starts almost perfectly, but refuses to hold idle and runs VERY rich. I can give it a little gas and it idles ok as long as I'm holding it. As I slowly take my foot off the gas it just drops and dies. I disconnected the O2 sensor completely and it runs a little less rich, but still rich nonetheless and won't idle.
Could the backfire have blown out my fuel regulator?
The vacuum line from the regulator is running to the three-way T where one routes to the intake manifold below the throttle linkage, while the other routes to the cutoff valve... Appears to be setup fine.
Any suggestions? (please help!)
'90 964 C4
Old 01-23-2012, 08:51 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Eric
Not sure what you changed when you pulled it a apart, but you should first check all the vacuum lines are in place.
The Motronic and fuel injection system the 964 uses is similar to that on the 944S2. Basically idle maps do not have O2 feedback - they are a fixed pulse duration (no adaptation) with adjustments for air temperature and engine coolant temperature. The DME adjusts the idle by the idle control valve which controls the bypass of air past the closed throttle body. More air = leaner, less = rich. It sounds like your ICV is either stuck closed or disconnected somehow.
I would suggest check the electrical connection as a minimum and also check all pipes. You should also check your AFM is connected as it used the AIT in this to determine idle fuel - although this is less sensitive as it defaults to about 20 degrees IIRC.
Also check the FPR (as you suggested) as I suppose it is possible that the excess pressure from the backfire damaged the FPR through the vacuum line connected to it. In which case you would probably end up with excessive fuel pressure and a rich condition. Off idle the DME can compensate to a degree through O2 adaptation.
Good luck.
Eric
Old 01-24-2012, 01:48 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Was it running fine before you worked on it?
1. If it does not want to idle, check to make sure the idle switch on the throttle body is making.
2. Go through all the vacuum lines and make sure they are all secured and seated. You have to remove the airbox or do a partial drop to get a better view of the backside of the engine compartment.
1993 964 C2
1996 318ti
2011 Silverado for hauling
Old 01-24-2012, 02:38 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Alps Adventurer
Traveller's Avatar
Send a message via Skype™ to Traveller
I don't know to what extent you had everything apart, but did you happen to stuff some paper towels into the intake tubes and forget to remove them? That would get you a rich mixture.
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 01-24-2012, 10:29 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
B. Elliott's Avatar
Thankyou for the input guys! Last night I inspected my idle control valve and it was stuck solid. I'm ordering one tonight so that I can at least have a good idle to diagnose from... if that isn't the only real issue.
Thanks again!
'90 964 C4
Old 01-24-2012, 06:23 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
