993 A-pillar door strap fix repair
Hi guys,
has any of you repaired this commonly loose door strap fix in the A-pillar? I am thinking if it is possible to cut out a piece of metal from inside, at the foot well and weld it from there??
I have heard some guys take the wing off and approach that way
Mike
1971 911S Black
1973 911S 2,4 Targa Hellelfenbein white
1973 911E 2,4 Vipergreen project
1976/77/78 930, Black/Silver/Guards red
BMW 2002ti tracktool
Old 01-14-2012, 12:58 PM
Door Check Strap Repair - Rennlist Discussion Forums
Old 01-14-2012, 02:19 PM
Thanks, i guess there is only the hard way..
1971 911S Black
Old 01-14-2012, 03:48 PM
There may be less involved methods, but I from what I've read, the most effective involved removal of the door and fender.
Old 01-14-2012, 07:45 PM
bri450sl's Avatar
Had my drivers and passenger door strap attachement point welded from the door opening. The shop did such a good job by welding around the entire piece with fine "fillet". They then sanded it and painted. If you did'nt know, you would swear it came that way.
Old 01-17-2012, 11:10 AM
I looked at the ways to do this repair and elected to effect the repair as did the last poster. I had the door check attachment lug (that breaks loose from the A-pillar internally) attached to the A pillar with an external fillet weld, both above and below the attachement lug. Then took a Dremel tool and cleaned up the fillet to look cosmetically nice. Then repainted the A pillar. The welder charged me $75 to make the fillet welds and to dress them down cosmetically. I used an air brush to apply epoxy primer and then to paint out the A pillar. The cost to do this with removal of the fender would have been over $500. Paint and welding cost me about $125.
In my opinion, unless you intend to compete in a concures, the external repair is both structurally and cosmetically fine. When I look at the area now, I really can't tell there has been a repair unless I compare it with the other door check.
Ernie
98 993 C2S - Arena Red/Beige
76 914/6 3.2 Conversion - Estorill Blue/Coral Red
Old 02-01-2012, 10:51 AM
