-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Where is the rear spoiler control module located? (http://forums.pelicanparts.com/porsche-964-993-technical-forum/654549-where-rear-spoiler-control-module-located.html)
mb911 01-30-2012 05:28 AM
I am trying to get the rear spoiler up and operational on the 1990 c2 I just got. It had an RSA tail on it and now I am putting it back the way it was. The spoiler switch was removed but it appears the harness is in tact. Just cant be certain as to where the module is. Anyone have a good break down of the complete parts break down of the spoiler components all the way to switch?
craig001 01-30-2012 05:51 AM
The module is located under under the dash in the passenger footwell at least in my 91. For the parts I would use the Pelican Parts finder.
964TargaC2 01-30-2012 08:54 AM
The module under the dash in the passenger footwell is the door lock module,
The spoiler control module in my car (production date 2/90) is under the passenger seat, as is the spoiler relay (96461814200)
I would suggest that you replace the bearing in the transmission...I didnt catch mine in time and motor seized..
mb911 01-30-2012 09:42 AM
what bearing? i am trying to piece it all back together right now and dont know about the bearing in fact if you talking about the tail trans i dont even have one yet.
964TargaC2 01-30-2012 04:38 PM
Yes I am talking about the bearing in the transmission, just a friendly tip, the OEM bearing is not sealed and gets corroded quickly, spoiler sounds like a coffee grinder...when you do find a transmission its an easy fix to replace the $4 bearing in it with a sealed bearing so you dont burn out the motor..when you do get one that is..
haasfogle 01-30-2012 04:50 PM
my 91 was above passenger footwell. (i have a duck-tail now)
haas
mb911 01-30-2012 05:57 PM
Any thoughts where I might find a used trans they about $500 new which seems rediculous
964TargaC2 01-30-2012 07:05 PM
Try Blackbyrd on this forum...$500 isnt ridiculous...its disgusting..especially since Porsche built it to fail using a non sealed ball bearing..
mb911 01-30-2012 07:10 PM
I got what I could from him (Efren) but he had nothing else. I need to find linkages as well looks like a long road back on this project:( I would thought these parts would be everywhere no one caries these part used
TMc993 01-30-2012 07:10 PM
Noisy Spoiler Drive on Porsche 964 & 993
911jettat 01-31-2012 12:45 PM
On a '90, it's under the passenger seat, see pic below (the black box with black tape on it):
https://lh5.googleusercontent.com/-i...c/s800/740.JPG
mb911 01-31-2012 05:23 PM
thanks that helps
