oil tank hose question
I have all 4 of the oil tank hoses for my 90 964 that needs replacing . My question is the longer 90 degree elbow is larger ID on the one end however both the t-stat and the oil tank fitting are the same size. was there a superceeded tank fitting and hose what am I missing here?
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 02-16-2012, 06:52 PM
BoxsterGT's Avatar
Porsche Crest
I think the rubber hose you are referring to is unique..........
and likely only available from our host or a Porsche dealer. The other short rubber hoses as well.
The braided hose from the Filter console to the oil thermostat below the tank is one I can make up for you when needed...........
You can supply the fittings and I will crimp new braided hose into a new assembly.
Hope this helps.
Len
Old 02-20-2012, 01:55 PM
