-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   1990 964 - Difficulty with removing brake pads (http://forums.pelicanparts.com/porsche-964-993-technical-forum/657237-1990-964-difficulty-removing-brake-pads.html)
Bedo 02-10-2012 11:41 PM
Any suggestions on how to remove stuck brake pads? I've separated the pads from all four dampers using a thin steel spatula (they now move back and forth between piston and caliper when pried with a screw driver), but they're not coming up (out) when tugging or prying... at all.
Arrowhead 02-11-2012 05:18 AM
You probably have anti squeel cups installed and if so you will have to remove the caliper with the bracket as a unit so it slides over the rotor. Then the pads will come out with the anti squeel cups attached. Or you have a very large lip on the outer edge of the rotor due to wear and someone forced new pads in there.
nickd 02-12-2012 05:33 AM
This is not going to be good news-
You almost undoubtedly have the typical aluminum corrosion beneath the steel spring plates above and below the pads that keep them snug. The only solution is to pull off the calipers and remove the spring plates to get at the corrosion. I would highly recommend shipping them out to have this done as the spring plate screws are cemented in with some amazing locktite and need an acetylene torch to get them out without destroying them.
The new pads will bind the first time you use them if the corrosion is bad enough- and it doesn't seem to take much (been there...).
There are a number of rennlist threads on the subject. A search for "caliper spring plate" will give more info. Good luck!
PNine64 02-12-2012 08:20 AM
IDK, I really think Arrowhead was on the right track with his comment below.
That said, I'm not sure that you have to take off the caliper to take the pads out. You can separate the anti squeal / mushroom / spider whatever they are called from the back of the pad with the caliper in place and slide the pads out (and then the anti squeal device). Here is an exchange on RL discussing the nest steps...installing new pads and how to mitigate squeal (although there are tons of these and mine still squeal :)). HERE
cjoenck 02-12-2012 10:39 AM
You are missing Bedo's point, I believe. He said that he "separated pads from the dampers" or whatever you call them. Reason they are not coming out could be:
- because of excessive wear of rotor as stated above
- Corrosion under the spring plate and someone modified old pads to compensate
I would pull the caliper - actually pretty easy to do - to get better access. You don't have to disconnect the breaklines for this.
TMc993 02-12-2012 03:34 PM
That's what I'd do, but if you don't disconnect the brake line, it'd be a good idea to have a second set of hands around to assist.
B. Elliott 02-12-2012 06:40 PM
Have you tried removing the entire caliper at all?
911jettat 02-13-2012 07:04 AM
Originally Posted by PNine64 (Post 6553494)
..........That said, I'm not sure that you have to take off the caliper to take the pads out. You can separate the anti squeal / mushroom / spider whatever they are called from the back of the pad with the caliper in place and slide the pads out (and then the anti squeal device).
I hope these pictures help...
https://lh4.googleusercontent.com/-A...d2%2520590.JPG
caliper through pad pins and clips
https://lh3.googleusercontent.com/-P...d2%2520600.JPG
https://lh4.googleusercontent.com/-6...d2%2520594.JPG
https://lh3.googleusercontent.com/-j...d2%2520597.JPG
https://lh3.googleusercontent.com/-y...d2%2520598.JPG
https://lh5.googleusercontent.com/-H...d2%2520599.JPG
Bedo 02-16-2012 03:20 AM
Job completed... almost
Thanks for all of the input guys - your comments have been very helpful.
After completing the following...
• buying a slide hammer and managing to remove all 8 pads
• cleaning everything up with brake cleaner and a wire brush
(I avoided the pistons)
• replacing all four brake pad wear sensors
• replacing all 16 Dampers
• slightly filed the pads for the two stubborn locations then repainted the raw metal with a similar epoxy paint
(not sure where I stand with 2011 tax returns yet)
• putting a light coat of Permatex anti-corusion paste on the contact "rails" (only) of all of the pads
• breaking-in the pads with a test run (it brakes straight, quiet and stronger with no shimmy)...
I have one remaining piece of the puzzle to solve.
The brake pad warning light on the dash still lights up!
I was very careful to make sure that all of the sensors were seated correctly to both the wring harness and pads. Is there any technique for resetting the signal? I cannot find a relay, so perhaps pulling the allocated fuse will do it?
Any thoughts would be greatly appreciated. Thanks again.
911jettat 02-16-2012 07:51 AM
I haven't had any luck installing pad sensors (or reusing old sensors)...so I followed this technique to bypass them:
Ditching the brake pad wear sensors: Ditching the brake pad wear sensors
(with the sensor disconnected you'll have to monitor brake pad wear)
PNine64 02-16-2012 10:02 AM
There is no resetting the system. When you fix it the light will go out. I did like jetta and zip tied mine up out of the way (although not bypassed). I would double check your connections.
Bedo 02-19-2012 11:11 PM
Job's Finished
I made the mistake of attaching the sensor wire to the wrong (empty) port on the wiring harness for the front right brake. I'll sleep better now. Thanks again for all of the input everyone. B.
