97 993 wont start
it will start first thing in the morning but sporadic starting after that. Thought is was the immobilizer as arming and disarming resolved the problem. Now it happens more frequently and I have to arm and disarm several times before it will start. generally hear no sounds whatsoever when have the problem but once in a while will hear a hissing sound that when i arm and disarm again the sound will disappear. is this an immobilizer issue or something else?
Old 02-20-2012, 07:27 AM
PNine64's Avatar
993s have the same DME issues as 964s don't they? Have you tried swapping that out? I know most of us 964 guys keep a spare handy for that "special occasion".
Old 02-20-2012, 09:24 AM
Don Plumley's Avatar
How old is the DME relay?
Don Plumley
M235i
Old 02-21-2012, 06:32 PM
Have someone hook a meter to the battery and monitor voltage as you crank to verify the battery has a good charge.
Old 02-22-2012, 05:56 AM
PNine64's Avatar
If electrical, the battery ground strap can cause problems (and is cheap to fix).
Old 02-22-2012, 06:19 AM
cgfen's Avatar
Try the START relay, maybe #61???, in the under front bonnet fuse panel.
Just swap it with another similar relay, there are 4 or 5 identical relays used for various tasks.
I had a occasional no start issue, swapped the relay around and have been golden ever since.
Craig
2012 Cayman R Chartreuse / 3 pedals
2009 2S Nordic Gold over Cocoa, my sweeties car (Chairman Meow)
2024 Audi A4 Allroad Navarra Blue over Grey
2010 Audi A6 Avant Grey over Grey - Supercharged!
Lottsa "steel is real" bicycles
Old 02-24-2012, 07:26 PM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
I agree with the relays thought process plus it is rather a simple item to test!
Once the car starts running does the engine sound fine or does it skip, spew smoke, anything outside the ordinary?
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 03-03-2012, 03:36 PM
