964 rear heater blower noisy
1990 964 rear heater blower in the upper left of the eng compartment is very noisy. Sounds like a bad bearing. Is the heater blower rebuildable? If not is it smart to find a used one? Appreciate any advice. thx
Old 03-02-2012, 03:39 PM
964TargaC2's Avatar
THE MOTOR CAN BE REPLACED, LOOK AROUND THE NET YOU CAN FIND IT FOR ABOUT $150. Bosch W0133-1602886 Blower Motor
- Direct OE replacement
You can also use the blower motor from the 993..just need to swap out the two mount bushings from your 964 fan
Old 03-02-2012, 06:18 PM
