89 964 c4 Front hub/bearing
I have removed front hubs and all other parts in order to install longer studs. On one
side, the seal covering the bearing came apart. Would someone please forward me a
diagramm of this section of the vehicle, because it is somewhat puzzling to me, to see
only a seal covering the roller bearing????? Thanks!
Maybe e-mail
hulbertknutie@yahoo.com
Old 03-13-2012, 03:55 PM
syncroid's Avatar
If the seal came out with the hub, you need to replace the wheel bearing. Probably a good idea anyway.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 03-13-2012, 05:05 PM
