-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   fuse panel change (http://forums.pelicanparts.com/porsche-964-993-technical-forum/67210-fuse-panel-change.html)
91C2wrencher 04-30-2002 06:46 PM
fuse panel change
I've ordered a new fuse panel and look to install it this weekend. There's an awful lot of wires under that thing, is there any tips or tricks you guys can share on this repair? 1991 964 c2
Roland Kunz 05-01-2002 11:53 PM
Hello
Just ubolt the old unit and swap over the connectors, fuses, bridges and relays.
Thats a 15 minute job.
You can remove the bulk panel to get more acces ( some little screws needing a 8mm nut )
OH remove the battery ground !!
Grüsse
