Architecture & Porsche's
Window dead; did broken switch fry motor?
Redirected my 964 turbo after a motor transplant but pass window is dead; tried a combo of all three switches & replaced a bad regulator fuse#4 but window still dead; did the broken switch on pass side fry something common??
Mark
Porsche Club Racing National Scrutineer '89 Andial 951 '82 928R '74 911 RSR 3.6 |
Did you put 12V directly to window motor? On the passenger side switch, pull the switch plug and connect 12V and ground to pins 1 and 2, I think. I will check my wiring diagram.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
I'd like to further diagnose this w/o pulling the door apart if testing the wiring from the switch to the motor doesn't work...but feel I don't have a choice at that point. Pin's 1 & 2 are labeled I assume??
If you have checked you are getting power to the motor I would suspect the motor is seized operate the switch in the down position and tap the motor with a hammer, my passenger side window has a tendency to seize now and again a few thumps on the door card is usually enough to get it working
