-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   964 transmission into split screen bus (http://forums.pelicanparts.com/porsche-964-993-technical-forum/685292-964-transmission-into-split-screen-bus.html)
group911@aol.co 08-08-2012 06:49 PM
Originally Posted by group911@aol.co (Post 6836451)
Bill
I might be wrong but I think the torque tubes are different 993 to 964. The 993 shaft is about half the diameter of the 964.
Bill
Finally got some time to compare. Ill do a separate post showing the differences but they are not interchangeable. http://forums.pelicanparts.com/porsche-964-993-technical-forum/693489-964-vs-993-torque-tube-differences.html
Geary 08-09-2012 05:42 AM
Yes, I'll be watching this thread closely, too. A VERY worthy project, Duke. :)
duke of boots 08-12-2012 07:19 AM
Flywheel/Clutch combo
Does anyone out there know if the 964 flywheel will fit a stock 911 2.0L motor? Will make this project so much easier if it does. :confused:
syncroid 08-12-2012 07:27 AM
It won't fit. A 964 flywheel is a 9 bolt pattern and the 2.0 motor is a 6 bolt pattern.
DW SD 08-12-2012 08:15 AM
I wonder if you can use a 964 clutch disc in between a 2.0 flywheel and pressure plate?
the 964 clutch disc is 240mm, I think.
Doug
duke of boots 08-12-2012 08:44 AM
Nuts
Ah nuts, well bolts actually and 3 too many. May have to be a bespoke flywheel. Thanks for the swift replies.
duke of boots 09-02-2012 12:08 AM
Flywheel builder
Can anyone in the UK recommend a flywheel builder?
Breckskier 09-02-2014 06:10 PM
How did this go? Just curious.. I've got a 13w deluxe at the body shop & about to turn a 912 to 911. Never considered a C4 Splitscreen....
http://forums.pelicanparts.com/uploa...1409710162.jpg
Would love to see more of how the project went.
duke of boots 03-07-2021 11:47 AM
Hi All. If anyone is interested this is how the build is going
https://www.ssvc.org.uk/phpbb/viewtopic.php?f=8&t=86279&sid=14f7cf273de49f2d546f 464567ac2cac
So far it has 964 front suspension, 996 rear sub frame, 993 engine, 981 gear shift - fun fun fun
duke of boots 10-02-2022 09:37 AM
How all Split Screens should be pushed down the road -
https://www.flickr.com/gp/78596025@N06/GNa6iqg6SX
duke of boots 10-02-2022 09:38 AM
https://live.staticflickr.com/65535/...c824e2e2_n.jpgBottom end in by Duke of Boots1966, on Flickr
duke of boots 10-02-2022 09:40 AM
https://live.staticflickr.com/65535/...79e1d6d9_n.jpgBottom end in by Duke of Boots1966, on Flickr
duke of boots 10-02-2022 09:42 AM
996 rear suspension
https://live.staticflickr.com/65535/...7f839ec2_n.jpgRear Sub Frame by Duke of Boots1966, on Flickr
duke of boots 10-02-2022 09:43 AM
964 transmission in chassis
https://live.staticflickr.com/65535/...2f4e057e_n.jpgChassis and Suspension by Duke of Boots1966, on Flickr
duke of boots 10-02-2022 09:48 AM
964 front trans and hubs with 964 steering rack mounted upside down
https://www.flickr.com/photos/78596025@N06/shares/G226h6WF8d
