-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   964 a/c problem (http://forums.pelicanparts.com/porsche-964-993-technical-forum/685379-964-c-problem.html)
stshbg 06-24-2012 01:39 PM
964 a/c problem
I have a 1990 c2 convertible with non-functional front blower fans. I dread the idea of replacing them due to cost and difficulty. I can feel cool air at the vents with no real force behind it. Is there a lo-tech alternative? Perhaps some kind of vent booster fan to pull the cold air out, something like the booster fans used with home central air vents?
RSTarga 06-24-2012 02:18 PM
If you are sure it is the fans you have no choice. It is not as big a deal as removing the evaporator but is not simple.
stshbg 06-25-2012 08:43 AM
as of now im ok with riding with the top down as this is a weekend car, but I may do a little experimenting. I'll let you know how it goes.
ToreB 06-25-2012 10:29 AM
Defective air flow control servos will severly affect the air flow. Are you really sure the fans are not working?
Details here:
Porsche 964 / 993 CCU electrical repair
Cheers,
Tore
stshbg 06-25-2012 11:40 AM
thanks Tore. Yes, I checked those this weekend and they work fine. I'm thinking the fans are stuck in that if I turn the fan speed above 3 it blows the #1 fuse.
swftiii 08-07-2012 01:04 PM
I just dealt with this recently as I was having an issue with one of the front blower fans. I removed it, cleaned it, and re-lubed it and now the fan moves smoothly and queitly. If you check the 964 forum on rennlist.com you can find a number of writeups. I took some pictures and started a writeup, but haven't finished it.
Good luck,
SKip
