Who makes steel fender flares?
Looking to put a widebody on my narrobody C4, and I wanted to use steel flares. Been trying to search for what's available out there.
Let me know if you guys have any leads/info. thanks. -Don |
Turbo flairs are avalable from the dealer or Restoration Design.
911/912 Exterior: Restoration Design |
+1 restoration design no affiliation.
Tony 91 964 c2 black/ Work in progress/Finally back on the road 85 EURO 930 Black slightly moded slowly reviving her 77 911tt EFI wide body red/ Slightly modified ![]() SOLD
Cool. I'll look into that.
thanks. -Don |
Are there issues using the 930 flares on a 964 other than the holes for torsion bar clearance which can be filled? thanks
1992, 964 Carrera 2, Midnight Blue 1998 BMW 318ti 2004 BMW R1100S BCR 2017 BMW R1200RS 2017 BMW 435i Mpower Pkg |
The 930 flares are shaped the same as the 965 flare, BUT where the torsion bar hole is completely different than a 965 or a 964 fender. There is a large cut out and holes for a shark fin (2nd half of a rocker panel) this covers that large different opening vs the 930 fender. jim jdorociak@gmail.com
Thanks Jim for this invaluable info.
Stephan
So where do you source the rear flares? I've only seen the older turbo flares available
thx '93rsa 3.8 |
the actual rear 965 flare is not available separately, but rather is the complete quarter panel. You could contact the Porsche dealer or a salvage yard, but just know these are very expensive. -- I think you could use the 930 flare and then modify by the torsion bar hole with the 964 cut out and test fit with a factory 965 shark fin. Jim
