Fuel in my intake plenum
Car was loading up and blowing very rich exhaust. Opened the lid and noticed fuel dripping from the bottom of the upper portion of the intake plenum. (beneath where the Idle Control Valve Muffler is located). Will be removing the air-box, and mass air sensor to get a better look.
- any one familiar w this symptom? - could it be a bad cold start injector (not even sure there is one)? - anyone experience a cracked plenum on a 3.6? - the intake popped much like older 911's do which typically is remedied by those familiar aftermarket pop-off valves. Any insight appreciated.
Coz 88 911 72 914-6 Vintage Racer 76 914-6 Vintage Racer Last edited by Imcoz; 10-25-2012 at 06:45 PM.. |
It's looking like it's a torn diaphragm inside the fuel pressure regulator. Fuel passes on one side of the diaphragm in side the component. On the other side of the FPR there's a vacuum line attached which goes to the upper portion of the intake plenum. The pressure in the fuel lines looks like it was pushing fuel past the torn diaphragm and up the vacuum line in to the plenum at a relatively high rate. There seems to be no other way fuel could get in to the intake this way.
If anyone has thoughts on this, please comment, otherwise I hope my post helps others.
Coz 88 911 72 914-6 Vintage Racer 76 914-6 Vintage Racer |
Yep, that's the only way excess fuel can get sucked into the intake, through a torn FPR diaphragm. $166.75 from Pelican.
How many miles on the car? I have 120k and still enjoying it. Do I need to plan on a replacement to avoid getting stranded?
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
In my experience its good to have an extra DME and a fuel pump around for an older car.
Wide body, molester.
Happened to me too. It was the WUR.
91- 964T, It's upkeep treats me like a skinny white kid in prison, but it does give me a reach around every now and then by letting me drive it. That's not so bad. |
Science is NOT optional
I have heard of this but have not seen it. Do you have a photo of where you are seeing the leak?
PCA member since 1993 |
![]() The fuel itself was leaking from the bottom of the upper portion of the plenum.
You sure you are looking at fuel and not oil? I would think that fuel would immediately evaporate on a warm engine. Oil on the other hand is more likely.
'91 C2 Targa |
It was fuel for sure. The fuel pressure regulator was bad and let it in through the vacuum line. I replaced it and cleaned the remaining components well. Was lucky enough to get it up to Lime Rock the day after and it ran flawlessly. In fact I believe there may have been a very small fuel leak at the regulator which caused the engine to run and idle somewhat poorly before the regulator completely failed.
