londonlhdcentre's Avatar
Blower
Hi all, on the 96 993 tip i have the heater blower speeds up when i put the car in reverse then slows down again when i go back into D, it's obviously an earthing thing, it's not really a problem but i would like to know if anyone has experienced this too
Old 12-28-2012, 05:03 AM
I've never heard of this before.
What blower is speeding up, the two front interios blowers or the rear AUX blower?
If the latter is the case, I would suspect some electrical short-circuit. Have you had your engine harness replaced?
Details on the blowers are given here
Cheers,
Tore
Old 12-28-2012, 09:04 AM
Hi, it's the in car warm air fan
Old 12-29-2012, 03:40 AM
Alps Adventurer
Traveller's Avatar
Cheers,
Tore
Tore, could it have something to do with the solenoid that closes a fresh air flap in the rear duct when the car is put into reverse?
I read about that somewhere but I haven't really looked into that feature since its not all that interesting, car-wise.
A "back-up" signal does go to the CCU.
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 12-29-2012, 07:14 AM
I agree Alex, that's why I asked if his engine wire harness has been replaced under warranty. Failing wire insulation could cause a short cirtcuit.
Cheers,
Tore
Old 12-29-2012, 08:30 AM
