-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Removing headlight switch - 993 (http://forums.pelicanparts.com/porsche-964-993-technical-forum/727503-removing-headlight-switch-993-a.html)
wongnc 01-07-2013 07:32 AM
Hello, just discovered this forum. I've got a 993 C4S and its my pride and joy.
The light switch has been a bit erratic recently. The headlights are OK, but when switched on, the dashboard lights go off and on intermittently when going over bumps. Loose connection? How do you get the switch off the dash board for repair (sand all of the connectors) or replacement?
Thanks in advance.
tholzer 06-10-2017 05:47 PM
Same problem and would love to see some simple instructinons
Ralph3. 06-11-2017 09:45 AM
Same question, but for 964.
drb930 06-14-2017 09:33 PM
The switch knob and switch holding collar come off from the front of the dash.
You then need to remove the switch from the rear of the lower dash.
To get your hand up there you will 1st need to remove the warning control unit which is held in with 2-10mm plastic nuts.
It comes out a lot easier than it looks with a good 1/4" drive metric sockets with the wobbly adapter extensions.
Loosen the box, pull it down to the area where you can get at the plugs and disconnect the 2 plugs.
The plugs have like a ratchet arm that disconnects them and remove the box.
You will now be able to get your hand up to where the headlight switch lives.
If you are on the larger size of body and or hands, you will have to remove the drivers seat 1st before any of this work.
Ralph3. 06-15-2017 09:14 AM
Any details on how to remove the knob and is the 964 the same. Does it just pull off or is it attached some other way? Most of the information I have found is for earlier or later cars. I have a new switch on the way maybe able to figure it out once I have is in hand. I have looked here and Rennlist and have not found any clear instructions. Thanks for the replies.
drb930 06-15-2017 09:35 AM
Know just pulls straight off.
964 & 993.r the same.
Ralph3. 06-15-2017 09:52 AM
Thanks for the reply, didn't want to break it during disassembly, new switch should be here today. :D
Raleigh993 06-15-2017 01:43 PM
Try some Deoxit Contact cleaner & lubricant (or any contact cleaner)
https://www.amazon.com/Hosa-D5S-6-DeoxIT-Contact-Cleaner/dp/B00006LVEU/ref=sr_1_9?ie=UTF8&qid=1497559285&sr=8-9&keywords=crc+electronic+cleaner
It worked on my headlight switch and did wonders for a balky ignition switch.
Ralph3. 06-16-2017 12:40 AM
You were right about the warning control unit although I used a couple of 9mm sockets and the outboard nut was a pain. Managed to get under there with out removing the seat but it was tight. Replaced the switch and rear spoiler dam.
Thanks again!!
