930 and 965 heat exchangers the same?
Would the 930 factory heat exchangers (along with the crossover and turbo mount pipes) directly bolt on to the 965 3.3?
Part numbers for the heat exchangers appear slightly different: 1. 965 3.3 Heat Exchangers (930 211 033 02) vs 930 Heat Exchangers (930 211 033 01) 2. 965 Exhaust Line (Crossover Pipe) (930 111 169 05) vs 930 Heat Exchanger Exhaust Line (930 111 169 05) - same part number. 3. 965 Exhaust Line (Turbo Mount Pipe) (930 111 003 06) vs 930 Exhaust Line (930 111 003 04) Thanks in advance! |
