993 tiptronic shifter knob
How do you remove the shifter knob on a 1997 Porsche 993 tiptronic I have the button off and I have removed the two small Phillips screws under the button but I can not get the knob off I've tried everything screwing it off pulling it off can some one help me thanks terry
Old 12-05-2012, 01:47 PM
Nine9six's Avatar
Terry,
If it is like the manual shift knob, it is a hard pull straight up off the shift stalk. Be carfull not to smack yourself in the face when it lets loose.
I took two long screwdrivers in parallell on both sides of the shift stalk and pulled up, per instructions posted on rennlist. It worked like a charm.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 12-06-2012, 07:06 AM
Does anyone know the answer to this for the auto shifter. I did the same as the first poster but have not had luck.
Old 03-22-2013, 05:51 AM
geolab's Avatar
rescrew the two screws back.
After you unscrew the click-knob plastic part, place a t-shirt on the shifter, hold it firmly and pull up. No twisting.
Be careful because when the shifter is off, there will be left the small rod in place.
If you pull up firmly and when it releases, your hands go back down, you will hurt your hands with the rod, thus the t-shirt
Old 03-22-2013, 10:53 AM
Thanks, That worked great. I just did not want to break it by pulling to hard. It actually already had a crack in the side so I might try to find another one.
Neil
Old 03-26-2013, 09:15 AM
