97 993 LW RS clutch/flywheel modification
A few months back I installed a new RS clutch and flywheel. The good news is that the car revs quicker and is more fun to drive, especially for DE days. Bad news is that the lighter weight causes the car to stall frequently. Have cleaned the idle speed control valve and it did help, but car still stalls!
So, I think my next remedy is to flash the ECU. This is an OBDII car so can't just chip it. Steve Wong has a good reputation with OBDI chips, but doesn't do OBDII... Have considered Rennsport (Oregon) or FVD in Germany, but this is not cheap! Does anyone out there have suggestions other than learn to heel/toe better? Very frustrating. Thanks
97 993 C2 Blistein PSS10, RS Clutch / Flywheel, FVD Sport Mufflers Recaro Pole Position Seats, Half cage and harness belts 2009 Cayenne S |
I had a 96 with a similar issue. I tried rotating the ICS valve to create a slower decel, but I finally scanned it and found a 1602 code. This was an alternator code (in this case). When this code occurs the ram in the ecu is cut off so the memory of the idle speed is lost. It is a two trip code so if the alternator does not spike in the next 2 cycles the code is gone and the memory of the idle is restored.
I have read on rennlist that a new valve will sometimes work to fix the stall even when the old one is squeaky clean. My 95 with LWF stalls only very rarely when cold. I thought the variorams were mostly immune.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 Last edited by johnsjmc; 12-10-2013 at 04:42 AM.. |
I have a 96, no issues. I havent heard of a 96-98 having stalling issues.
GC |
Rereading your post ,occasional maybe but FREQUENT stalling is not usual for a 96 up . I would fully look it over for small vacuum leaks while running at idle. Wiggle fittings etc. There are lots of small vac hose possibilities for leaks.
You can also use a spray can of brake cleaner or an UNLIT propane torch to find leaks while its idleing.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 Last edited by johnsjmc; 12-10-2013 at 04:48 AM.. |
All - I too thought the 97 cars would be immune to the problem, but...
I checked for air leaks and am about to replace the ICS valve (have cleaned the old a couple of times). Will try the Steve Wiener battery disconnect procedure as well. Thanks for the help! Steve
