Radio/CD player trouble!
Having trouble with my Becker CD/Radio player. After replacing my problem battery, my CD player keeps locking half on. The display face lights are on, but no functions work.
Only way to fix is to disconnect battery & re-install the code. Works for half an hour & then lock - with display face on. Any body had a similar problem? Any fixes? |
It sounds like the hot lead to the radio has a bad connection which when interrupted causes the unit to go into "help Ive been stolen mode" and you have to re enter code
Check leads at battery and see if there is an additional lead off the positive terminal, that may be the culprit.. |
| All times are GMT -8. The time now is 09:20 AM. |
