993 stalling
have a'95 993 w/a lightweight flywheel. sometimes stalls upon deceleration, downshifting. any ideas as to what problem is?
Old 08-25-2013, 03:57 PM
The lightweight flywheel.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 08-25-2013, 04:21 PM
It may be a software problem or an ISV problem...Take a look at this.... Fixed My LWF Stalling Problem - New ISV - Rennlist Discussion Forums
Old 08-25-2013, 06:59 PM
Northern Motorhead
wildcat077's Avatar
I recently installed a 95 3.6 in my 89 and i have a Patrick lightweight flywheel along with a KEP lightweight pressure plate and i believe the Steve Wong chip that i also swapped in my DME addresses the stalling issue.
I've never had the car stall on me !
Cheers
phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 08-25-2013, 07:23 PM
+1 on the ISV
If you review past posts, you will note that it has been a unique issue that the 95 is the only model year 993 that appears to be sensitive to stalling when the LWF is installed.
You may have to replace the LWF with one of Steve Weiner's Mid Weight Flywheels that he is now producing particularly for the 95. The disc weighs a few more pounds then the LWF which provides just enough momentum to prevent the stalling on decel issue you are experiencing.
I would also either clean or replace the ISV since they have been known to hang up and cause or exacerbate stumbling or stalling on decal. There is a DIY on cleaning the ISV on this site. Just remove it and flush the ISV with carb cleaner until the valve can be rattled. Cleaning the ISV or, in worse cases, replacing it may minimize your issue; but, since there has been so much written about stalling issues in 95's with the LWF, I think that ultimately, you will need to upsize your flywheel to solve the issue.
Ernie
98 993 C2S - Arena Red/Beige
76 914/6 3.2 Conversion - Estorill Blue/Coral Red
Old 09-02-2013, 08:54 PM
