-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   964 Cab Starting Issue (http://forums.pelicanparts.com/porsche-964-993-technical-forum/768878-964-cab-starting-issue.html)
Aviator53 08-31-2013 02:28 PM
90 964 C2 Cab...relatively new battery kept on trickle charger...shows 12.8v but cranks like stereotypical low battery/dead battery. Runs fine once started but each start is the same even after driving it. Grounding strap/cable is free of corrosion...not sure about starter. Any ideas? Thanks.
Aviator53 09-08-2013 11:02 AM
Update
Removed the cables running to the starter and cleaned up the contact points and still have same issue. Of note was that the solenoid (?) had a brown finish with some paint peeling...could this be due to high heat and possibly part of the problem?:confused:
Newsboy 09-09-2013 02:08 AM
Did you check the battery ground strap? Swap the battery with another & give it a try. Or take it to Sears or similar place for a test.
