Clutch won't move after bleeding !
Replaced master. Slave and slave line. I ran two liters of fluid thru a motive power bleeder. Clutch won't press in ? Any help is VERY appreciated. Thanks. John
I see no air bubbles but clutch still won't budge ! Don't know what I did wrong ?
Now clutch just falls to the floor and won't come up ?
Back to clutch being stiff. Can't count how many times I've bled now.
do you have the slave pushrod engaged into the dimple in the fork for sure?
Thank you john walker's workshop for responding to me. You are correct. Dimple to the side and ruined by pumping of clutch. New slave cyl should be in tommorow. Targa964c2 pointed me in this direction also... I'd been in" clutch bleed hell "for hour's... Talk about feeling dumb ! thanks again.
