02fly's Avatar
alternator repair
Anyone know how hard it is to repalce the Alternator in a 1996 993, also should I buy a bosch rebuilt or take mine and have it rebuilt.
Old 09-16-2013, 12:10 PM
Just replaced mine on my 95. Getting the fan off was the hardest part of the job. Good time for new belts and fan/shroud powder coating. I went with Bosch
Old 09-16-2013, 12:36 PM
02fly's Avatar
So you pulled the whole fan and housing out?
Old 09-16-2013, 12:53 PM
Yes. Mine is a 95 non v. Intake unlike yours. But I think it's similar removal. Once bolts to strap and duct removed it lifted out enough to unbolt the wires. Btw. Take your fan belt sensor off or you will probably break it.
Old 09-16-2013, 01:13 PM
02fly's Avatar
Thanks so you pull housing also? I was looking at the sensor and it looked like it would be in the way. What about a RS pulley
Old 09-16-2013, 01:32 PM
Yes. You'll be surprised how easy it lifts out. Housing and all. After you put your new one in its easier to put the belt detector on with a little elect tape wrapped around the spring loaded wheel. Then take it off after you tighten the Allen head screw. RS pulley ? Have one now or going to it ? Good time to Change over. I didn't. P-car has a good tutorial on this job if needed.
Old 09-16-2013, 04:00 PM
02fly's Avatar
Great Thanks, I'm diving in tonight
Old 09-16-2013, 04:12 PM
02fly's Avatar
Ok I got the housing and fan out (not a hard job at all) But how is the aternator held in the housing, do i need to get the fan off to see.
Old 09-17-2013, 07:54 AM
There are some long screws holding the alt in the shroud
Old 09-17-2013, 08:57 AM
02fly's Avatar
Got it, Thanks. Now come the pain in the ass of trying to get the fan off I think I'm just going to use a three bolt puller and pull the fan and hub at one time, the articale on pcar showed the guy taking the fan off then pulling the hub but he was installing a RS pulley setup.
Old 09-17-2013, 09:15 AM
Don't break any fan blades. Those are $. I had to soak mine with PB blaster and slowly tighten the puller. Hopefully your fan bearings aren't wore out. I had to replace mine. Good luck. John
Old 09-17-2013, 09:37 AM
