4 piston rear brake calipers
This is a cross post as I am looking for a set to replace my 2 piston rear calipers:
WTB 4 piston rear 964 calipers
Is this a direct bolt on and are there any other modifications that I need?
Thanks, Mark
1973 911 3.0 (sold)
1980 911 SC (sold)
Old 10-29-2013, 06:39 AM
964TargaC2's Avatar
While it is a direct bolt on you may want to either replace the brake proportion valve (Part 9643553-510) or gut it.
I swapped out the 2 pot rears for the 4 pot and since I dont track the car have yet to change out the valve.
You can also use the 944 turbo rear calipers, you just have to swap out thebleeder valves to the crossover pipe...simple enough
I am sure BillV will come along and give his position and I would definitely listen to what he says!
I think that maybe I'm dreaming..
Old 10-29-2013, 07:27 AM
creaturecat's Avatar
there is a set for sale on Vancouver c/list.
Old 10-29-2013, 12:27 PM
trak ratt's Avatar
I did this on our '91 w/the proportion valve. Easy swap and much better for finding brake pads for the track.
Old 10-29-2013, 03:13 PM
Thanks for the heads up to change out the brake proportion valve as well. I guess I will add that to the list.
Old 10-30-2013, 06:03 AM
