-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   964 3.6 engine build (http://forums.pelicanparts.com/porsche-964-993-technical-forum/786383-964-3-6-engine-build.html)
GBX 12-10-2013 03:51 PM
I may be simplifying this too much, but what's a good street engine setup on a 964 motor, if I were looking to make more power and spend between $5k and $10k?
Any help would be appreciated. Thanks!
boba 12-11-2013 05:28 PM
Unless the engine needs a rebuild leave it alone. A 6 speed out of a 993 will wake up the car and be in your budget. If you have some $$ left over improve your suspension. If you want to spend more you could re-gear the box, look at G50-31 ratios.
tocobill 12-11-2013 05:51 PM
Get a good condition engine and drive it until it needs a rebuild. Give you some time to get over the initial purchase of the engine which is going to be 6-8K maybe a little more depending on condition. If your doing a conversion into an earlier chassis then it might be alittle more for all the conversion parts .. harness, clutch, oil lines, etc. If your set on building a engine I would piece meal out the parts so you can get a really nice engine without having to by a core motor and end up replacing parts that are worn out of spec. 993/964 parts get expensive quick.
jhg41977 12-12-2013 04:17 AM
A stock rebuild is going to run most of your lowerend if you do the break down and assembly. If you have a shop do the break down and assembly, you will use the upper end and possibly more.
dmark9 12-17-2013 08:46 PM
Hi GBX,
I just rebuilt mine. I ended up putting it back to factory specs and it's fast enough for me for now.
PM me and I'll give you a name of a contact at a parts place that can talk through this with you. His prices are great too. He's built many 964/993 motors. I was looking to get GT3 bearings and some other stuff, and was told not to spend the money if it will mostly be a street car.
One area that's recommended is to get aftermarket connecting rod bolts. Seeing how quickly we get to redline, I'll do this next time.
I put the motor back to factory specs and installed a new clutch, and the updated 997 throw out fork, slave cylinder and hose and bought some special tools too. All for about $4K to $6K.
Sounds like you know what you're doing. If you want to watch a DVD on how to do this and all the steps, take a look at our 964 Engine Rebuild DVD at P Fix It | Porsche 964 | Repair & Maintenance Videos.
Good luck,
Denis
