Whoopsies I was banned!!!
Esel Mann's Avatar
Crush washer(s) confirmation for oil change
From what I can see, when performing an oil change there are 3 plugs which are removed as part of the drain process: crankcase, thermostat, and oil filter housing.
If this is anything similar to oil changing on predecessors, these plugs each have a crush washer? Per our host, for the 964 there is call for 3 crush washers, part number 900-123-118-30-M131.
For anyone who has actually performed an oil change on a 964, can you please confirm that:
(a) all 3 plugs have crush washers;
(b) all 3 plugs use the same type crush washer.
Old 01-06-2014, 03:24 PM
I do not open the oil filter housing. I hammer a nail in the oil filter to allow air in and then open the thermostat plug. Then tape up the hole before undoing filter.
1990 964 C4 Cab
2008 Range Rover Sport (daily driver)
Old 01-06-2014, 04:51 PM
Newsboy's Avatar
Crush washers are the same on engine sump and oil tank.
Old 01-07-2014, 03:48 AM
Esel Mann's Avatar
Thanks for the input!
So the crush washer for the crankcase and oil filter housing are the same.
That leaves the crush washer for the thermostat plug....
Anyone know/confirm if the crush washer for the thermostat plug is the same as the above two?
Old 01-07-2014, 07:08 AM
So the crush washer for the crankcase and oil filter housing are the same. NO
Crankcase seal ring: PN 900 123 118 30, A22 x 27, Plug M20 x 1.5
Thermostat seal ring: PN 900 123 118 30, A22 x 27, Plug M20 x 1.5
Oil filter seal ring: PN N 013 813 2, A12 x 17, Plug M12 x 1.5
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 01-07-2014, 10:07 AM
Esel Mann's Avatar
bazar01,
Thanks for the clarification and the part #'s!
Old 01-08-2014, 12:00 PM
