72' 911S
leadrsa729's Avatar
Send a message via Yahoo to leadrsa729
Fuel Pump Test
Hello -
Anyone know the correct wire gauge I should use to run voltage directly to the fuel pump from the battery on a 1993 RSA in order to test if it's working?
Thanks for your help!
Old 01-09-2014, 06:41 AM
It's on a 15 amp fuse, so a 14 AWG will do. !2 AWG is better.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 01-09-2014, 07:30 AM
72' 911S
leadrsa729's Avatar
I'll go for the 12 then, thanks!
Old 01-09-2014, 07:40 AM
Newsboy's Avatar
Remove DME(fuel pump relay) R-41 and jump a wire across # 3 & 7 . This should run the pump.
Old 01-10-2014, 02:45 AM
Good advise.
Not sure if the OP had the pump on the bench.
Old 01-10-2014, 05:16 AM
