Cedric 18's Avatar
Porsche Crest Fuel injector valve wire issue
I was wondering if anyone knows if there was an upgrade on the wiring for the fuel injector valve for the 964. Please see the pictures attached. The red/green wire coming off the middle valve has been cut off, and the red/green wire from the next sensor is connected to a black wire that goes to the DME I figure. I am just wondering if I should have that other red/green wire connected to the black as well????
Car runs fine but I am just going over all the wire harness to find any corrosion or damaged wires and I saw this.
Thanks for the help.
Cedric
Old 01-13-2014, 08:02 AM
efhughes3's Avatar
What is with all of the hose clamps? Is that a home made fuel line?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 01-18-2014, 07:44 PM
That would be a power steering pump line, but I agree that it has way more clamps than normal and a hardline portion that doesn't look factory either.
Old 01-18-2014, 10:04 PM
