RS Cup Air Tubes Available
At long last! Over-due, and over-budget, but they're here and they're beautiful! Just in time for winter!
Those of you who have done or are working on a 3.6L conversion, this is the part you need to finish off your conversion. This unit gives you much better heater flow than cobbled-together systems of heater hose and duct tape, and you won't be ashamed to open your engine compartment any longer.
If you have a C2/C4, use this to shave off extra pounds high up in the engine compartment, exactly like the factory did it.
This piece is lighter than the original used to mold it from, but I don't have an exact weight because my scale isn't sensitive enough. It's that light. I'll try and find a postal scale and come up with an actual weight figure.
I only had 10 made, and a few are already spoken for. This wasn't a cheap project, and I'm barely covering my costs. I spent the extra time and money to ensure it was done right.
These are the only repros available, and originals are NLA. Used ones are few and far between.
For more info, go to http://vintagebus.com/rstube
Old 09-20-2002, 08:53 AM
PRO Motorsports
Tyson Schmidt's Avatar
I want one!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 09-20-2002, 09:39 PM
