Cedric 18's Avatar
Traction control LED on a 964 C4
Please let me know if anyone has had this problem before. Once the car is warmed up, every time I go over a bump on the road, the yellow LED on the traction control lights up, if it stays on for more than a second the red warning lights comes on and stays on.
Any idea?
Old 04-14-2014, 08:16 AM
I've seen the rough-road behavior before; I think it's either related to ABS or possibly the lateral accelerometers. Which red warning light are you talking about?
'90C4
Old 04-14-2014, 10:00 AM
Cedric 18's Avatar
the one on the center console with the exclamation mark, I can turn it off when it happens. No abs or PDAS light comes on tho.
Old 04-14-2014, 02:19 PM
Are you certain all your dash lamps work? I've never seen the ! by itself...
'90C4
Old 04-14-2014, 05:09 PM
Cedric 18's Avatar
no I am not, should all the lights turn ON before you start the car? or how can I check them all? Thanks.
Old 04-15-2014, 07:40 AM
Not quite all as there are some which are unused. Pretty sure I've seen photographs of the startup display, and there may be one in Streather's "Enthusiast's Companion". Search around a bit and if you can't find one I'll post up a pic of my startup display.
'90C4
Old 04-15-2014, 09:51 AM
Cedric 18's Avatar
Thanks, I will search around but if you have one of yours it would be great though.
Old 04-16-2014, 07:26 AM
