oil pressure gauge problems
Having some problems with my oil pressure gauge. First off yes there is oil in the car.
The oil pressure gauge will go down to 0. I will tap on the gauge and it wakes back up. I already changed the oil pressure switch and check the harness connection at the back of the gauge. The oil pressure light is also coming on. I am thinking the gauge may need to be rebuilt. Can anyone share some advice about what else to look for before I spend the money on rebuilding the gauge? Thanks
Old 04-25-2014, 03:22 PM
964TargaC2's Avatar
check the grounding (brown wires)
I think that maybe I'm dreaming..
Old 04-26-2014, 06:49 AM
crg53's Avatar
I would hook up a manual oil pressure gauge just for piece of mind. You didn't mention how many miles are on the engine.
Old 04-26-2014, 07:25 AM
SouthCoastPhil's Avatar
had a similar problem with my 93 c2 964. once it warmed up and at idle, pressure gauge drops to 'danger will robinson' level. scared the sheet out of me (yes, lots of fresh oil).
Had my tech replace the sending unit. still a problem. checked gauges with his 964 and gauges were consistent and fine.
had him test pressure manually and all was fine.
now in process of replacing ground straps and cleaning contacts.
88 Venetian Blue Coupe "B"--gone, but not forgotten
93 964 C2 Coupe "BNC" ("PNC" on some days!)--PSS9s, Big Reds, Strut Brace, Recaro SRDs, Schroth 5-pts, DAS bar
Old 06-08-2014, 02:33 PM
