-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Replacing gear shift boot? (http://forums.pelicanparts.com/porsche-964-993-technical-forum/815460-replacing-gear-shift-boot.html)
JV44HeinzBar 06-09-2014 11:23 PM
Hi,
I recently bought a new gear shift boot. It actually came with instructions on how to remove the boot from the console. Unfortunately, it also said that the console needed to be removed. I vaguely remember a post about the shifter boot replacement, but I don't recall having to remove the console.
If I need to remove the console, how do I go about doing this job? The spoiler knob and 3 other toggles are connected to the console, but I don't see how to remove them. I've notice that the console trays have some screws that could be removed, but will that allow me access to hidden screws holding the console in place?
TIA,
HB
briefescape 06-10-2014 08:21 AM
Definitely do not need to remove console . Just press down around the edges of the boot and the ring will pop down and then just pull the boot out at an angle . Very simple .
Cheers Guy
JV44HeinzBar 06-10-2014 01:07 PM
Thanks Brief. Just to verify, once I angle the new boot in, I just pull back up on the boot so it locks into place?
HB
briefescape 06-10-2014 04:57 PM
correct !
JV44HeinzBar 06-12-2014 10:25 AM
Thanks Brief,
I popped the old on off and installed the new one by using the procedure listed. It took all of 5 minutes.
HB
